- Joined
- Nov 16, 2021
- Messages
- 9
- Reaction score
- 1
Currently I am troubleshooting, as mentioned earlier sometimes my vTiger contacts do get recognized but sometimes they dont.
Because the test option gives an error in v20 (in v18 the test worked fine) I gave the problem to AI:
The error System.InvalidOperationException: Sequence contains no matching element in the 3CX log indicates a mismatch between what the CRM integration expects (e.g., a refreshToken) and what your vTiger CRM actually returns (a sessionName). Here is the solution:
What Needs to Be Done:
csharp
// Replace this:
var refreshToken = response["refreshToken"].First(); // CRASHES because "refreshToken" does not exist
// With this:
var sessionName = response["sessionName"].First(); // Use the field that DOES exist
Seems like this can't be done?
Cause of the Error
The code of the 3CX CRM integration attempts to retrieve a refreshToken from the API response of vTiger, but vTiger only returns a sessionName. This occurs in the StoreAuthData method, where the code uses a LINQ query (such as .First() or .Single()) on an empty collection.Solution
1.
The XML template is correctly configured for vTiger and already retrieves the sessionName (see the <GetSessionName> scenario). The issue lies in the underlying C# code of the integration.What Needs to Be Done:
- Search the code for all references to refreshToken (e.g., in StoreAuthData) and replace them with sessionName.
csharp
// Replace this:
// With this:
