Thank you for your comments and help. Now that Update 7 is out, I tried the updated Zendesk integration. While it helped some, it does not completely solve the issues. The primary issue is related to is taking action if there is more than one result returned. I see from the Salesforce template I believe that using this expression in a Scenario Skip if
Code:
[IIf([FoundRecordCount]>1,True,False)]
Would cause the Scenario to be skipped if more than one result was returned. Therefore no output would be populated for that Scenario.
Based on the Salesforce template, if I create multiple "Matching Scenario" each with the above skip, I could get two scenarios in the template, but only one would populate the output variables.
This should allow me to set the needed Zendesk URL.
Does this seem like it will work?
