CRM Log variables set, but system says contact number is not found
ealanhill
New User
When I go to test my CRM integration, it says: "CRM integration functions properly, but the contact number is not found. Review the log for details or attempt a different number."
I'm sure I'm doing something dumb, but I'm not spotting it. When I review the logs I see this:
Started scenario with empty id
Request text: https://crm-odata-v1.prospect365.co...'1234567)&$select=DivisionId,Name,PhoneNumber
Response text: {
"@odata.context":"https://crm-odata-v1.prospect365.com/$metadata#Divisions(DivisionId,Name,PhoneNumber)","value":[
Response finished
Finished scenario with empty id
Request text: https://crm-odata-v1.prospect365.com/Contacts?$filter=contains(PhoneNumber,'1234567')
Response text: {
"@odata.context":"https://crm-odata-v1.prospect365.com/$metadata#Contacts","value":[
"ContactId":8785,"DivisionId":7858,"AddressId":7908,"MainAddressId":null,"DeliveryAddressId":null,"Individual":0,"RoleCode":"UNKNOW","Title":null,"Forename":"John","Surname":"Doe","PreferredName":null,"Salutation":"John","JobTitle":null,"Department":null,"PhoneNumber":"(1) (222) 1234567","Fax":null,"Email":"[email protected]","EmailBounced":0,"SecretaryName":null,"SecretaryPhone":null,"SecretaryEmail":null,"MailFlag":0,"FaxFlag":0,"EmailFlag":null,"SwapFlag":0,"SpokeCode":null,"SpokeDateTime":null,"DateOriginallyCreated":"2024-05-10T15:51:15.311415Z","SurnameSoundex":616,"ForenameSoundex":2917,"StatusFlag":"A","Source":null,"AlternateReference":null,"SearchTerms":null,"Created":"2024-05-10T15:51:15.311415Z","CreatedByUserId":"MS1","LastUpdated":"2024-05-10T15:55:29.022Z","LastUpdatedByUserId":"DBA","LastUpdatedTimestamp":"2024-05-11T09:06:50.847Z","SystemObjectsKey":"8785","SearchCached":1,"OptIn":0,"MobilePhoneNumber":null,"ImportSourceRunId":null,"RecordLink":"/view/Contact/8785","SystemSearchTerms":"John Doe","KlaviyoId":"","MergedWith":null,"AccountsId":null,"SyncFieldHash":null,"LastSyncError":null
Response finished
Variable ContactID set to 5555
Variable FirstName set to John
Variable LastName set to Doe
Variable CompanyName set to
Variable Email set to [email protected]
Variable PhoneNumber set to (1) (555) 1234567
Variable PhoneMobile set to
I have the same issue. All variables are set, but I keep getting the message "CRM integration functions properly, but the contact number is not found."
Did you find the solution?
Set the matching digits to 9. That's because the number being sent is 0032... when the returned number is +32. The system is most likely set to "Match exactly".
That setting in v18 is under Advanced > Contacts > Options. In v20, it's under System > Phonebook > Options.
Also, ensure that you are mapping the variables to outputs. The variables are an intermediate step, if you don't provide outputs for the name, phone and ContactUrl, the contact will be discarded.
intoxtech
