CRM Template Generator ¦ Beginner-Question
Marcel Odermatt
Gold Partner
Hi together
Im trying my first steps with the CRM Template Generator. The Goal is to get CallerInformation from a public phonebook. They have a rest-api and the response is in xml.
Now i can run a request and get the response back. In the "response Text" i see the whole xml file. But in the "Response Tree" is only the first line. I've attached a api-response-xml. thanks a lot for any help.
Hello Marcel,
This is a known issue with XML responses. We will be fixing this in the near future. Meanwhile, can you make the request in a way that the server returns JSON instead of XML? That way you avoid this problem.
Kind regards.
unfortunately not. We will wait till the update.
thanks for your information. kind regards
costionofrei
