CRM Template I can't get data from a list
dperuzzo
Platinum Partner
Hello !
I created an integration model for my own CRM.
I am not able to get data from a list for PhoneBusiness
How can I set this?
I tried that. It also didn't work.
The only way is filtering the record. If you can change the web server response, then this is an example of how you should generate the response:
JSON:
"phones": [
"number": "79692284200",
"type": "work"
"number": "89692284201",
"type": "mobile"
As you can see, each item in the array specifies the phone type. Then you can use the filters as follows in the XML template when defining the variables:
XML:
<Variable Name="PhoneBusiness" Path="customers.phones.number">
<Filter>
<Rule Type="Equals" Ethalon="work">customers.phones.type</Rule>
</Filter>
</Variable>
<Variable Name="PhoneMobile" Path="customers.phones.number">
<Filter>
<Rule Type="Equals" Ethalon="mobile">customers.phones.type</Rule>
</Filter>
</Variable>
I have no way to change the CRM response.
Is there any other way to obtain this information?
What you can do is defining an Output with the number being searched, this way the returned record will be considered a match. For example:
<Output Type="PhoneBusiness" Value="[Number]"/>
However, please note that if the contact has other phones, they will not be added to the 3CX Contact when more than 1 phone is returned in the array.
Mueller
