CRM with changing contact URL per extension
Daan L
Platinum Partner
Our customer has a CRM where each department needs it's own contact URL. The contacts are in the same database, but the contact URL differs per extension. Normally 3CX will only support 1 URL with a variable (contact ID).
We can create an extra table in the database, so I want to create an extra variable based on the user extension that receives the call.
The extra table:
Extension [Agent]URL
101URL1
102URL1
201URL2
202URL2
301URL3
302URL3
etc
I want to setup the URL as following:
Variable Name="ContactUrl" Path="https://[ContactID]
Is it possible using an API of do I have to write a custom SQL query?
It would be great if it's possible without an extra table.
Please remove this topic.
Thank you!
You can't do this. The Contact URL must be unique per contact.
Mueller
