Solved CSV Bulk Import issues with phone template
Alphabetic
3CX MVP
Good Afternoon,
Im trying to import some extensions and i've got "PhoneTemplate14" set to "YealinkT4x.ph.xml" but when I import i'm getting this:
Extension 201: phone template 'YealinkT4x.ph.xml' not found,
Extension 202: phone template 'YealinkT4x.ph.xml' not found,
Extension 203: phone template 'YealinkT4x.ph.xml' not found,
Extension 204: phone template 'YealinkT4x.ph.xml' not found,
Can anyone help?
Ok it didnt like the capital Y in Yealink.
sorted it.
Okay, now i'm unable to get in to any extension :(
a new extension works fine just not from my import.
Update 1
Narrowed it down to something in my PhoneSetting that it doesnt like.
what is the minimum that needs to be in PhoneSettings for it to work?
Ok I just did 1 extension manually then copied the phonesettings.
Im assuming that's the normal way to do it. working fine now.
devo.it
