Custom Button Label Width SIP-T46U
YerBabiE
New User
Can the label width on a T46U be changed? It seems that the handsets have a whole heap of avaliable space that they dont use, causing button labels to be unnessasarity truncated.
thanks in advance.
The behavior you see is the way Yealink designed it (firmware & template combination).
We would recommend to look up Yealink's documentation on this, as this is not something that is controlled via 3CX.
Just keep in mind that if you need to modify the template to achieve this, your 3CX system will be in an unsupported state, and you might face issues going forward (both with firmware updates, template updates, and functionality)
Stephan Eusebe
