Po Huang Platinum Partner Advanced Certified Joined Sep 26, 2021 Messages 27 Reaction score 2 Sep 26, 2021 #1 Hi, i have done an simple crm template from crm generator and a littile modified. it could fine the user data . but can not pop up the contact url . could help me check what is the problem Attachments gastomsPo.xml gastomsPo.xml 1.6 KB · Views: 1
Evolute IT 3CX MVP Gold Partner Advanced Certified Joined Feb 6, 2018 Messages 11,249 Reaction score 7,113 Sep 26, 2021 #2 You need to return a ContactUrl variable, which is also the primary key when doing the updates to the internal phonebook. The variable can be built using parameters and static text or simply a URL pointing where you want. Just know that it should be unique per contacts. Reactions: edossantos
