Solved Custom FQDN Lets Encrypt renewal problem
greychain
Gold Partner
Custom FQDN's are not supported so I don't know that you'll get much help here. But I'm not sure why you would try to redirect anything to a 3CX port since 3CX isn't handling the SSL you are.
Hi @greychain !
This is one of the great benefits if you use a 3CX FQDN/SSL Certificate, all the renewals are handled automatically by the system and you don't need to worry about it.
I hope you figure it out, but just a reminder, if you don't you can always switch to using a 3CX FQDN.
OK fixed, couple of small issues.
In the /etc/nginx/sites-enabled/your-pbx file I enabled port 80 in the 2nd server section where it uses port 5000.
In my router I had to forward port 80 to the server, the certbot doesn't seem to use SNI so needed to physically point port 80 to server.
run the certbot renew command
Kayla Norris
