custom template for polycom 335 phones
tylachau
I'm trying to modify create a custom polycom template with new device settings. Where in the .xml file for the template would I put the following settings???
Code:
<Phone_Config>
<All
attendant.resourceList.4.address="224.0.1.75:50002"
        attendant.resourceList.4.label="Page"
        attendant.resourceList.4.type="automata"
        ptt.address="224.0.1.75"
        ptt.allowOffHookPages="1"
        ptt.callWaiting.enable="1"
        ptt.emergencyChannel.volume="-1"
        ptt.pageMode.allowOffHookPages="1"
        ptt.pageMode.displayName="93700"
        ptt.pageMode.enable="1"
        ptt.port="50001"
        ptt.pageMode.group.1.label="Plant"
        ptt.pageMode.group.1.subscribed="1"
        ptt.pageMode.group.2.label="Corp"
        ptt.pageMode.group.2.subscribed="1"
        ptt.pageMode.group.3.label="All"
        ptt.pageMode.group.3.subscribed="1"
        device.net.vlan="15"
    </Phone_Config>
I would add the code at the end of the template and see if it works.
This way, when you templates are released you can easy add your changes to the end without scrolling thru the code.
I copied the template to the custom templates folder, and pasted the code in the file I created there. It didn't work. I don't know where it has to go between the tags. Its impossible to find anything on the polycom website.
fransisco
