Debian 9 to 10 on Intel NUC
gluetome
I have a V16 Debian 9 on an Intel NUC and used the upgrade tab on 3CX dashboard several times-to move to V18 + Debian 10. It failed each time. Log file attached here. Do I need to download 3CX Debian 10 and perform a fresh install on the mini PC or is there a work around.
Thanks for any assistance.
It's generally easier to just spin up the new ISO on a USB key and reinstall from scratch.
Remember to make a full backup and download it to your computer beforehand.
Restore during 3CX Setup Wizard.
we use intel NUC for some clients, don't forget to manually make update & upgrades on the debian 9 (via ssh for exemple). doesn't work for us if we didn't do it before the 3cx V18 change.
@gluetome it seems to be an issue with dpkg.
Reboot the machine please and try one more time.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
> Download failed (upgrade)
Thanks. I re installed V18 on the same Intel NUS, the whole process took no more than 5 minutes.
