Debian - Cannot upgrade to 15.5 SP5
Toufic Saghbini
I would confirm you have direct internet access currently from your server, have any network changes occurred to your knowledge - try a ping to google or something like that and see if it works.
Yes, Server has internet, in fact its a cloud server on Microsoft Azure.
If you try to browse the above file from your pc, you will also get a not found error.
Depending on what version you are using you could try (or try amending to suit what you want to upgrade from >> to) this guide here - using the command line of the Debian instance instead of directly from 3CX: https://www.3cx.com/blog/docs/upgrading-debian/
Obviously you are going to need a bit of Debian Linux know-how.
megalmazan
