Debian "Cannot write to ‘-’ (Broken pipe)." Problem HELP
sahamott
I get error during installation with ssh.
1.Command for installation
Code:
wget -O- http://downloads-global.3cx.com/downloads/3cxpbx/public.key | sudo apt-key add -
And debian error code;
Code:
-                     0%[                    ]       0  --.-KB/s    in 0s
Screen :
11221
what is problem ?
Code:
Code:
Screen :
what is problem ?
The problem is that you are running the command with elevated privileges (as root?) and do not require 'sudo' on the apt-key add command.
If you see ": #" you are already running with elevated permissions.
If you see ": $:" you need to add sudo
Drop 'sudo' from the second half of the command after the "|"
The command should look like this:
Code:
wget -O- http://downloads-global.3cx.com/downloads/3cxpbx/public.key | apt-key add -
fcentral
