Debian "Cannot write to ‘-’ (Broken pipe)." Problem HELP
OmarSaber
I don't see @OmarSaber using sudo in the screenshot although it was indicated in the code line. The error seems to indicate the lack of gnupg, gnupg2 and gnupg1.
@OmarSaber If you can't troubleshoot this basic error message I recommend installing from the 3CX ISO so all the dependencies are in place and you have an install that just works
[email protected].
