Decommission Cloud Instance
Brandon5540
Greetings, I'm switching from the cloud install (created using the PBX Express wizard) to a on-premise windows install. Anyone know how I get rid of the system in the (google) cloud?
Thanks in advance!
Brandon
Reach out to 3CX support. They can close it down for you.
Reactions: Brandon5540
Hello @Brandon5540
Please note that 3CX support can delete an instance that is hosted by 3CX. If the PBX was hosted in your own instance then you need to delete it your self.
megalmazan
