Dect Snom on M700 unregistered to registered
Antoine83
I have 3CX Debian Intel NUC
Trunk OVH
5 D785 phone who works perfectly!
My 12 dect phones (connected to M700) are randomly (every 2-5-10 minutes) disconnecting with this msg:
Extension 007 is unregistered, removed contact: sip:[email protected]:5060;line=2313
and registered just after (30s to 1min)
I don't understand, my M700 provisionning method is local LAN
If you have an idea, don't hesitate
Thank you very much
What firmware is running on the bases and handsets? Is it 3CX supported?
Are you running in multicell mode?
Base M700
Firmware Version: IPDECT/04.00/B0002/30-Oct-2017 13:12
Handset M65
Firmware: 355.25
Multi cellule
Multi Cellule statut: Idle
Système Multi cellules: Desactivate
ID Système chaîne: 512
Synchronisation heure: 60
Synchronisation Data: Multicast
Primaire Synchronisation Data IP:
Debuguage multi cellules: None
You could experience issues like described if you have different bases with different firmware's. Also handsets are recommended to have same firmware version as bases.
If provisioned as per: https://www.3cx.com/sip-phones/snom-m300-m700-dect/
Ensure you do no have the FFFFFF handsets IPEI into the provisioned settings.
If you run a PCAP from the base station when the phones are in this "un-registered" state what message is reported as the reason for the register failure ?
All handset and base are in the same firmware 400 2
After reboot, it works for an hour
But I have same problem after each 2-5 minutes.
Sip000 unregistred 1 minutes ago
I disconnecter M5 Extender to be sure it's not the problem
Here are the sip Log of base m700:
a78105c97839d", algorithm=MD5
User-Agent: snomM700/04.00.0002 (MAC=0004136165B8; SER= 00000; HW=255)
Content-Length: 0
Received from udp:192.168.100.182:5060 at 23/07/2018 10:16:04 (449 bytes)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.171:5060;rport=5060;branch=z9hG4bKwfc74xpnab7hyx09zezh6n.echar71
Contact: <sip:[email protected]:5060;line=62526>;expires=11
Contact: <sip:[email protected]:5060;line=14165>;expires=120
To: <sip:[email protected]:5060>;tag=e5c9401c
Call-ID: 63ufgqkr
CSeq: 41428 REGISTER
User-Agent: 3CXPhoneSystem 15.5.13103.5 (12071)
Content-Length: 0
Received from udp:192.168.100.182:5060 at 23/07/2018 10:16:04 (451 bytes)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.171:5060;rport=5060;branch=z9hG4bK2.yvtldmp3vrpl9mwrrei.xhyy4
Contact: <sip:[email protected]:5060;line=39623>;expires=120
Contact: <sip:[email protected]:5060;line=53209>;expires=15
To: <sip:[email protected]:5060>;tag=e8181f6f
From: <sip:[email protected]:5060>;tag=p6wa5yrd4tvl
Call-ID: 1r07am59p
CSeq: 27803 REGISTER
Content-Length: 0
Sent to udp:192.168.100.182:5060 at 23/07/2018 10:16:04 (559 bytes)
REGISTER sip:192.168.100.182:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.171:5060;rport;branch=z9hG4bKot.z5b9xqui3e
Max-Forwards: 70
I don't have FFFFFF handsets IPEI.
Do you tthink i can try to provisionning with STUN or SBC method?
GemmaC
