Default all internal calls as intercom (*7) calls
TheRydad
Is there any way to set my 3CX so that all internal (extension to extension) calls are treated as intercom calls?
We use our desk phones as an intercom system. Currently, I have the BLFs on each phone configured as speed dials with *7xxx as the number (xxx=extension). It works, but it's a hassle to setup compared to just picking the extension for the BLF. I was hoping there might be some clever way to have all internal calls prepend the *7.
-r
If your phones have an internal, configurable, dialplan, that could be written to prefix all dialled extension numbers.
Thanks. That got me headed in the correct direction. I added
<=*7>xxx
to the top of the dial plan so that any 3 digit number will be pre-pended with *7. I also had to uncheck Multi-Purpose Keys (MPK) from the "Bypass Dial Plan" option in my phones. Now I can have BLFs that make an intercom call when selected! Hurray! I even got the added benefit of getting the extension status on the BLF LED on the phone.
However, when I re-provision the phone, it resets the dial plan. Can you nudge me in the right direction to add this dial plan to phone templates? Is there a master template file somewhere?
This is really fantastic progress. I really appreciate the help.
-r
Okay. I should have at least bothered to look in settings and I would have already found the answer to this. I did find the template for all phones in the Templates section of Settings. Duh.
One follow-up, still- Is there a way to set the dial plan for softphones and the iOS and Android apps?
-r
-r
Unfortunately, no. Mobile apps and Webclient dialplans can't be changed.
Thanks for the help, everyone!
-r
hughesdouglas
