Default email template
Frdoc
We've customized the "welcome extension" email template but I'd like to get back to the original version.
How can i get back the default template for version 18.0 update 8?
Thanks in advance.
Fr
Hello @Frdoc
In Hosted by 3CX installations you are not able to see the Parameters as in Self-Hosted installations.
You will have to copy the "welcome extension" template content from a PBX that the template is not modified and paste it to the Email Templates of your Hosted by 3CX PBX. From the Management Console navigate to Settings > Email > Email Templates and select the Extension Welcome template from the drop-down menu.
Hi Dimitris,
Thank you for your feedback.
No problem for me to copy the template but I do not have access to the orginal one :-)
Could you send it to me?
Thank you.
BR.
For this, it would be best to contact your assigned partner as we are not able to send you the HTML body for the Extension Welcome.
Jake_Southern
