Define Remote-Party-ID by extension
vishal.l
Platinum Partner
I have 2 different trunks, and for 1 of them, i need to do this:
Define Remote Party ID - Calling Party : User Part by extension. It can't be in the users Outbound Caller ID.
¿Any ideas?
What do you want to define in that field that will be by extension? You want to send the extension number there?
Yes, i would like to send the extension number. Or a combination of numbers and ext number, for example
111222 301
111222 302
111222 ???
This can only be achieved by populating the information in the outbound caller ID option of the extension. Other than that option, the only variable the PBX can send out from the extension settings is the name of the extension. I cannot think of any other way to do this.
Okay, thanks...
Reactions: YiannisH_3CX
Keep in mind...because of the proliferation of Spam calling, many providers will no longer permit a caller ID that is not in a standard format, as used within the country, that is, if they even allow numbers, that were not issued by them..
Yes, i'm aware. Not the issue cause i'm also the provider
admintest
