Delete 3CX PBX instance
GDLV
How could I delete a 3CX PBX instance and more particularly the DNS entry. I need to reinstall and there is IP conflict with the different instances.
Gaëlle
  • 3CX Version, the last one installed by PBX Express
  • Server OS, Debian 9
  • Is the 3CX Server Hosted and where? OVH CLOUD
  • IP Phone Make/Model/Firmware
  • Provisioning Method: Local / VPN / STUN / SBC
  • Trunk Provider or Gateway Make/Model ;: not yet
  • Has the Firewall Checker passed: ?
I tried to install three times and the problem was the FQDN was not redirected well by your DNS because IP changes ... I wasn't aware of deleting instance before reinstall ...
So for now you have a Cloud instance installed with PBXpress on OVH. So if FQDN was previously pointing on another Public IP, then you just need to wait DNS propagation, time to wait from 5 minutes to 6H , depends on which type of 3CX license you have, ENT ttl 5 minutes, STD & PRO 6 hours.
you just neef to wait, do a nslookup time to time to see if DNS is updated.
