Deleting free licence after replacement
AndyCoo
SMB User
I've run into an issue with creating an additional On Premise instance after upgrading another one from the free licence.
When I try to get the config file from www.3cx.com/install it shows the below:
The newly upgraded instance shows correctly in the portal system list
But I've still got the old free licence showing up
There are two buttons inside the licence, Delete & Unlink, but I'm not sure which of them will properly remove it from the account and allow me to create a new instance.
My understanding is the normal procedure is to create with a free licence, test client's services, upgrade to commercial licence.
Could you DM me one of the licence keys or the FQDN so we can look at the correct account?
thanks,
KS
Thanks, I've sent that through now.
You just need to Delete that trial key.
Thanks Kyriacos. Once deleted I was immediately able to continue on the www.3cx.com/install page.
Reactions: KyriacosS_3CX
albertpugo02
