Deleting Old Call Reports
Shadragon
Good Day,
Call Reports are stored at:
C:\ProgramData\3CX\Instance1\Data\Http\Reports
on the 3CX server. To delete them, I can only do one at a time which is hardly efficient. If I set up a script to delete files after 2-3 months directly in this folder, will this have any negative effects?
Thank you.
Yes, all your call reports will be gone :) In all seriousness though, I can't see any negatives outside of the links in the emails will no longer be valid (because the reports were deleted). 3CX shouldn't depend on them in any way.
Hello @Shadragon
I cannot see any implications by doing so just make sure you do not delete any reports needed or the logo folder
Reactions: Shadragon
(Thumb up)
Thanks all.
estrezacafe111
