Department-Based CRM Integrations – Multiple CRMs within a Single 3CX System
ArneDery
Platinum Partner
Current limitation​
Currently, 3CX only allows one CRM integration to be configured at system level. However, in many organisations, different departments rely on different CRM platforms and business applications.
For example, a Sales department may use a traditional CRM platform, while a Service department relies on a dedicated ticketing or service management solution.
Today, organisations that require multiple integrations often need to rely on third-party applications, middleware or custom-developed solutions to overcome this limitation.
Proposed solution
Introduce CRM integration as a department-level configuration option within 3CX.
This would allow administrators to:
  • Configure multiple CRM integrations within a single 3CX system.
  • Assign a specific CRM integration to each department through the department settings.
  • Perform contact lookups, call journaling and contact creation based on the assigned CRM integration.
  • Configure a system-wide default CRM integration for departments without a specific configuration.
  • Reuse the same CRM integration across multiple departments where applicable.
Practical use case
Within a single 3CX system:
  • Sales Department → HubSpot
  • Service Department → Zendesk
  • Finance Department → Microsoft Dynamics 365
  • Administration → Default CRM integration
Each department could continue using its preferred business applications while benefiting from native 3CX integration capabilities.
Benefits for the 3CX ecosystem
  • Greater flexibility for organisations with multiple departments.
  • Reduced dependency on third-party middleware.
  • Lower implementation and maintenance costs.
  • Improved integration capabilities for larger and more complex organisations.
  • Greater commercial opportunities for 3CX and its partners.
  • Increased adoption of native 3CX CRM integrations.
Conclusion
With departments already being a fundamental part of the 3CX architecture, extending CRM integration capabilities to department level would be a logical evolution of the platform.
3CX should adapt to the business applications an organisation uses, rather than requiring an organisation to adapt its business applications to a system-wide CRM limitation.
This feature would significantly strengthen the 3CX ecosystem and make the platform even more attractive to organisations with diverse operational requirements.
It would be interesting to hear from other partners and administrators who are experiencing the same limitation.
Upvote 2
Active Telecoms
