dial a code after phone pick-up
Robbejanvdw
SOHO User
We have a gate for our park space and would like to be able to open this with phone calls.
We have a Fanvil I30 which can open the gate after you enter a code through the phone.
But the problem is we aren't always able to dial in the code. and we are now using a gsm gateway module, but it is broken, we are looking to be able to open it with our 3cx pbx.
Is there any possibilty to create a script or call flow that dials the number of the gate and dials the code after it has picked up the phone?
Or are there any other solutions for this problem?
Any help would be appreciated!
The easiest is to use a Speed Dial BLF, with the code added already. Normally, you can do pause or things like that in the dialing to allow what you need.
Like "*4<ext>,,1122" where the comma is a pause.
Thanks for the reply.
Tried that in different ways but he won't accept it. I tried it on a Yealink T46G.
Also this would be no solution to call from external cell phone numbers?
Any other way you can think of?
VOIPEric
