Dial after 11 digits entered automagically?
dlev
Is there a way to avoid pressing the "enter" key after the number is typed into the softphone? There's no dial hotkey -- just looking for a solution to streamline things.
To be able to recognise when you have finished dialling a number, and then immediately send that number off to the PBX, requires that the device has an internal dial plan. You would then create digit maps so that the phone knows when any number, internal, external, local or long distance, is complete. Many VoIP devices have this ability, but I'm not aware that the softphone is one of them (at this point).
Yealinks used to dial automatically after a few seconds of inactivity, but they removed this feature and I am in support of it, it was really annoying when dialling long numbers of which you need a bit of time to dial.
Wecare_ITA
