Dial by name list
Rey Cobham
Is there a way to see which extensions have correctly set up the Dial by name feature?
Hello @Rey Cobham
I am afraid that there is no way to see this through the management console. You can look into each extensions folder however to see if the user recorded a self identification message.
The path for windows is C:\ProgramData\3CX\Instance1\Data\Ivr\Voicemail\Data\extension_number
For debian: /var/lib/3cxpbx/Instance1/Data/Ivr/Voicemail/Data/extension_number
Ah good point, so a simply script could check those folders and create a csv file or something...hadn't thought about that. Thanks!
hughesdouglas
