Solved Dial by name not working
Edo-JV
I've tried multiple things on different extensions, and I can't get the dial by name to work.
I did this step on 3 extensions to test the dial by name, and it does not work.
1) Set up a Digital Receptionist with the Dial by Name option in it.
2) Put a name and surname in each extension's settings.
3) Go to each extension's voice mail option 9 and 5 and record their full name as the self identification message.
Does anyone have an idea?
The the extension voicemail prompts, I do not see the .wav file, is that normal?
I got it resolved, it actually required the message to be saved, it was not clear in menu, since it's in french.
Reactions: Edo-JV
intoxtech
