dial code to pickup parked call?
dandenson
SOHO User
Is there a way to dial a code on an ATA attached cordless phone to pick up a parked call? Has to be numeric, can't dial SPx.
Create extension 771,772,773 and forward each to an external number SP1,SP2, SP3, etc.
Then those phones can dial the 3 digit extension (I use 77 because that is the number for S and P)
There could be occasional issues with this - it is not officially supported.
Reactions: accentlogic
Any other "dial codes" used from an ATA connected phone generally require a flash/dialtone before using. Most codes are industry standard, to an extent, across different manufacturers, but in many cases, can be customized. there is usually a list, in the device GUI.
@ craigs answer worked.
now, any way to park calls? I guess *0 doesn't work here.
transfer 771
no transfer key on a cordless.
flash button?
so just hook flash and transfer to the 'forward' extension? in this case, 4 digit extension so I did 7701, 7702, 7703. hook flash, 7701, once it rings, hang up?
There is attended transfer and unattended transfer.
As i recall, to do an unattended transfer from an ATA (which i assume your DECT phone uses), you have to do a flash, then the code for unattended transfer (check the ATA), then the extension number, then hang-up.
The flash, plus extension number only, means you must wait for the person to answer, then hang up.
Reactions: craigreilly
SaschaA_
