Dialing 0 zero for Operator no longer works on v16?
Thiek
After upgrading two of our systems to version 16 I noticed we can longer dial zero within the building and get to the operator extension. Used to be, under the ext. setup for the Operator, "options" tab, we could place 0 under SIP ID and this worked nicely. v16 broke this and I don't see anywhere new to set this up.
I don't know how to do this?
I just attached an example post.
Thank you, this is what I needed :). Would have never found that setting even if I spent all night digging thru v16 manual (lol) assuming that exists.
There were a lot of posts about that right after people began installing version 16, as you can imagine.
I did a key word search using "operator zero 0" and didn't see anything, maybe I didn't dig deep enough.
I tend to find that a google search, including the word "3CX", and what you are looking for, brings up more "hits". In your case, it's primarily a SIP ID issue which happens to affect the zero for Operator, for version 16.
[email protected].
