Solved Dialing a contact with a number starting with + (plus) sign for country code
Code Craft
How can we dial a contact with a number starting with + (plus) sign for country code on the Android 3CX softphone application and have the 3CX PBX system strip the prefix + (plus) sign?​
Reactions: ChrisC_3CX
Just want to add that, from the two options @Saqqara mentioned, we recommend using the Outbound Rules to reformat these numbers which will give you a bit more control.
Solved: Thank you for your input. It got me on the right path to resolving this issue.
Brilliant! Happy to see you sorted this out!
Do feel free to post anew should you need anything else!
Bluebox Global
