did not shown in owner role
bit101
Hi togehter,
if a user has the role "owner" then he cannot see the did from any extensions.
We have a customer they has sub admin users and they have to configure new extensions with dids.
Currently dids are not showing.
Does anyone know how to configure that?
thanks & regards :-)
If you are referring to a sub-admin, you can assign them the "System Administrator" role, which has fewer permissions than the "System Owner." This will allow them to configure the DIDs.
system administrator is to much. They should only has Owner role or smaller
I can see that with owner rights, we can configure the DIDs, as well as access voice, chat, and many other options. 1729763704832.png
OK will double check that later again
Reactions: bit101
Ok i found the problem.
So when the trunk is set to "System Wide" in Limit to section then the did field is empty by the users (pls see screenshot).
When i set the trunk to "Default" then i see the dids.
So we can closed this case, thanks!
regards
regards
That would be my next suggestion. The department owner has no systemwide access
It works now. We can close that ticket. Thanks!
Reactions: bitn2
AshleyStokes
