Different settings depending on days
Lukas2019spec
Hello, I have some riddle how to configure different rule calls depending of days ? I am looking possibility and only in dummies extensions can change different rules ...but on hours.
The perfect way in 3CX should be in "Configure Holidays" possibility set some extension, queue, IVR but there is only prompt :-( please help my .....i really need to change rules of couple future days and don't want to switch this manually every day.
In other IP PBX this is common feature in easy way to change....
..thank you in advance for your help...and sorry for my English
Reactions: Lukas2019spec
I have not used this Call Flow Designer before but i'll try, thank You....I have PRO version by the way
There is a dedicated Call Flow Designer forum section you visit if you face any issues or if you are searching for a solution.
estrezacafe111
