Solved Digital Receptionist terminates call
prewest
When I use the Digital Receptionist it terminates all calls when the caller picks a choice.
Even picking the Transfer to Voicemail results in a terminated call.
I have also tried the timeout so that it fails over to an extension, also then the call is terminated.
I am using the latest 15.5 version.
It only happens when I call via my SIP Trunk, if I call with a SIP phone to the extension number the issue is not present.
Any ideas of what i`m doing wrong?
Fixed it, I needed to uncheck "Support re-invite" in the SIP trunk.
Glad to see the issue has been resolved and thank you for updating the thread with your solution. Let us know if further assistance is required.
Bluebox Global
