Digital receptionist
Algodigital
How do you can let the digital receptionist answer when the company number is called? Should it be set in the inbound rules? And if so how?
Please do not reply with this link (https://www.3cx.it/doc/manuale/risponditore-digitale-ivr/ ) which only explains how to create the digital responder but not how to set it to let it answer when customer calls. I'm new to 3CX so I have not found a way to get this done...
You point the sip trunk, trunk to the digital receptionist extension number.
If you sip trunks, check out the section 'Route calls to' on the General tab of the sip config
Select 'Destination for calls during office hours' to extension and select the extension number of the digital receptionist.
I've done. It works! Thank you very much for your help :).
3K8iMGWviZ
