Marius87 Customer Joined Jan 23, 2025 Messages 3 Reaction score 0 Jan 23, 2025 #1 Hello, I have a question. How can you configure 3cx so that after connecting, the Dinstar gateway sends SMS to a specific number? Marius
Alejandro_3CX Staff member 3CX Support Joined Dec 6, 2016 Messages 1,737 Reaction score 892 Jan 23, 2025 #2 Hi @Marius87 I'm afraid that you will need to check it with Dinstar. Better to use a supported voip provider to use the SMS feature. Reactions: edossantos_sipcaller and N_G
edossantos_sipcaller 3CX MVP Customer Joined May 2, 2024 Messages 1,351 Reaction score 1,736 Jan 23, 2025 #3 Most probably that gateway provides a REST API that will allow you to send the SMS. So you could use the 3CX Call Control API to listen for the call connection event, and then use this API from your gateway to send the SMS.
