Direct hyperlink to text message
brendanr
New User
Hi guys,
Similar to the tel: protocol for dialing out, is there anything similar for text messaging? Or is there any way we can create a link (button on our CRM for instance) which will directly send a text message through 3CX?
Thanks in advance :)
Hi! Unfortunately there is not feature at the moment that would allow a "tel like" hyperlink that would immediately launch the Desktop App in the chat window with the number prefilled.
Thanks Nick, is there anything similar that would open the 3CX desktop app and automatically insert the number? Or even using the API? Thanks.
Not that I can think of unfortunately.
Generally our Messaging implementation is meant to be P2P, so there are no API calls that allow you to programmatically send or interact with the Messaging part, at least not at the time of writing and that I am aware of.
rsaldin@advancedbrainspin
