disable CRM integration
Steve Bootes
SOHO User
I'd been playing around with 3CX integration with my CRM system (Autotask) but want to stop it popping up new ticket windows when someone phones. I figured I'd just disable the integration until I had to time to diagnose it further.
However, when I set the Server Side CRM Solution back to "None" I'm still getting the popups from the integration code!
Does anyone know how I can permanently disable this?
3CX 18.0 Update 2 Build 314
2 things:
- Whenever you edit, change or disable the integration, go clear up the CRM Contacts (via Advanced > Contacts > Delete > Delete CRM Contacts)
- To disable just the popup, in the Webclient/DesktopApp, you can go under [...] > Settings > Integration, and set it to Off.
Also, might wanna DM me. We have one for Autotask already.
NathanMitchell
