Disable "dynamic ip address changed" email-notification
LukasG
Hi there,
when a 3CX PBX is configured in dynamic public ip address mode I get a notification-email every time the public ip address changes.
Is it possible to disable this specific notification?
This notification doesn't appear to be a part of any of the events whose notifications can be configured under Settings -> E-Mail -> Notifications
Thanks in advance,
Lukas
Hello @LukasG
Unfortunately disabling this notification is not currently possible as it is built into the system. We are adding more though with updates so perhaps this can be added as an option.
Reactions: patrik.hegedus
Thanks for your reply and too bad.
If you could add this option I (and a customer of ours) would be very grateful.
hughesdouglas
