Disable IPv6
Helmut72
I want to disable IPv6 on Debian 9:
Code:
helmut@3CX:~$ netstat -an | grep LISTEN | grep -E ':50..'
tcp        0      0 0.0.0.0:5060            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN
tcp6       0      0 :::5090                 :::*                    LISTEN
tcp6       0      0 :::5060                 :::*                    LISTEN
tcp6       0      0 :::5000                 :::*                    LISTEN
tcp6       0      0 :::5001                 :::*                    LISTEN
And after reboot:
Code:
helmut@3CX:~$
When I now disable IPv6 on the OS and reboot the Management Console does not come up:
Code:
tcp        0      0 0.0.0.0:5090            0.0.0.0:*               LISTEN
helmut@3CX:~$
The reason is nginx:
Jun 04 14:36:49 3CX nginx[1509]: nginx: [emerg] socket() [::]:5001 failed (97: Address family not supported by protocol)
Jun 04 14:40:48 3CX nginx[1688]: nginx: [emerg] socket() [::]:5000 failed (97: Address family not supported by protocol)
as /var/lib/3cxpbx/Bin/nginx/conf/nginx.conf still contains:
Code:
listen [::]:5001 ssl http2;
listen [::]:5000;
Commenting those lines solves the issue:
Code:
helmut@3CX:~$ sudo /etc/init.d/nginx start
Starting nginx (via systemctl): nginx.service.
helmut@3CX:~$ sudo /etc/init.d/nginx status
_ nginx.service - A high performance web server and a reverse proxy server
   Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2020-06-04 14:42:28 CEST; 36s ago
     Docs: man:nginx(8)
it works as intended, as the sip server will not use anymore 5060 on IPv6 which would maybe be used to connect to a VoipProvider. The other IPv6 service listed as inbound Ports (tunnel and web). You may close them from your NAT but even then I would leave them to give every client the best option to connect to your service.
You have already been told not to mess around with Debian and disabling IPv6 thru the management console.
https://www.3cx.com/community/threads/too-many-incorrect-login-attempts.73795/#post-331501
That does not disable IPv6 but only stops SIP from using IPv6. That's a huge difference. In my case I get a dynamic IPv6 from my ISP so I cannot restrict access to the web console properly. That's a security issue. And yes, I can do workarounds like firewalling, reverse proxying and so on but it remains an issue.
Unfortunatley IPv6 does not do NATting so I can't. And with a dynamic IPv6 I do not have an option to restrict the webconsole from the internet which is the only thing that concerns me.
To illustrate:
Private IPv4, no problem, RFC1918 address. With a dynamic IPv6 (internally, at home!):
Issue, I cannot restrict web console access. so as soon as I activate "Allow Access from specific IP Address" I lock myself out. See my other topic.
Leave it alone and either put a firewall between the internet and 3CX or use a host based firewall like iptables or something. Or just leave it and trust 3CX to do it's job.
Puppet does the job, np.
Wecare_ITA
