Disable Keytones ?
PaulCFT
Titanium Partner
is it possible to disable the Keytones on Yealink handsets on 3CX (the beep you heard as you press each digit when entering a number) ?
There is an option in the handset to disable them but I believe this will be overwritten each day as the handset is re-provisioned and I can't find an option in the 3CX itself.
Hi @PaulCFT the parameter by default is enabled in the template, it is not possible to change, it will need custom template which it is not supported.
Take care!
Reactions: PaulCFT
In case you are wondering, this is the setting to look for if you want to disable the key tones:
features.send_key_tone = 0
features.key_tone = 0
SupportRock
