Disable outbound calls outside of working hours | v20
Nee_BinaryCity
Good day,
We would like to know if there is a way to disable/prevent outbound calls for the PBX outside of working hours (to apply to all users on the system). We are on Version 20.0 Update 3 (Build 806 Release).
We know of the setting per user, under schedule, but with 200 plus users, this isn't realistic to apply to all users manually.
Regards,
I believe this is the only way
Reactions: Nee_BinaryCity
My assumption is that this property is accessible via the Call Control API. You could create a service that on a schedule manipulates that setting.
As i think you can use Parameter setting :
youwillbrun
