Disable recording.
MMDTerry
This hasn't been a problem in 5 years, but today while doing something else I noticed the "recordings" stat shows storage used. Odd since we do not record anything. Well, one user is trying to use it for less than honest reasons it would seem. All users have the call recording set to "recording off" under user>options>call recording. I do see the greyed out "allow users to start and stop recording" option, but I figured that would be a null point if recordings are already off. Or is it a free-for-all all unless you buy up to ENT?
You need the enterprise licence to deactivate this stuff.
This option is enabled by Default and cannot be changed unless you under an ENT license:
The OFF just means that recording is OFF unless a user presses record. It's the default state toggle.
Enterprise gives you control over the "recording" button and combined with the default state, can allow you to force it always off or always on.
ARKC
