- Joined
- Aug 8, 2019
- Messages
- 24
- Reaction score
- 0
I have a customer with agents in a 'Ring All' queue, but if they press the 'divert to voicmeail' button it gives the 'voicemail disabled' which it is. All the 'forwarding fules' for the agent are setup to forward back into the Queue. It's a 24/7 dispatch center, so ending a call isn't really an acceptable practice. If I could disable that button it would work as well, but any solution would be helpful. THANKS!
I see lots of posts about the end call but nothing specific to our case. Any input is appreciated.
