Display SIP Info on Snom M80
platinum
Hello There
We've got a server that is tasked with alarming multiple M80 DECT phones via a call and has it's own extension on the PBX.
The alarm code gets read to te recipient via text to speech, the alarm code is also sent in the SIP Display Info.
I couldn't find a way to display the SIP Info on the M80 at all. Is this even Possible?
What could be a possible method for displaying the alarm code on the display?
I know the Yealink phones display the SIP Info for incoming calls, but i couldn't find a way to get it working on the Snom M80.
Kind Regards
3CX will simply send an Invite to the set. The set will normally display the number/name caller Id information sent. To display another field, from the Invite would be a (change to the ) function of the set itself, unless the "message" originates as caller ID (name).
bosdorf
