display the current profile in the display of the phone
ubsysteme.de
Is there a way to show the current profile in the phones display?
If I change to DND this is shown in the display using a small Icon and the text "do not disturb".
If I change to lunch or away nothing is shown. How can I visualize the current profile?
3CX 15.5.10244.4
snom D715
Regards
Hello @ubsysteme.de
Please note that by default you cannot do this on an IP phone. You could however use the Web client that does display the status of your extension and the status of other extensions in the PBX.
Unrelated to your issue you need to upgrade to the latest stable version of the PBX to avoid activation issues as i see that you are still on SP4.
Due to a change to the activation server, earlier versions of the PBX are no longer able to authenticate and activate. If for any reason your system needs to re-activate it will fail resulting in the PBX reverting to Free.
You can upgrade easily using the guide below: https://www.3cx.com/blog/news/pbx-upgrade-update-6/
thanks for the reply and the information about the update.
The Web client works as aspected.
What means "by default"? Is there a "not default way" to go?
Regards
By default i mean the default behaviour of the phone system and the default provisioning templates. I am not aware of a non default way of doing this but someone else might. I would still recommend using the web client for this.
jmarshall
