Distributing Outbound Call Equal on SIP Trunk
Deepak | Aastitva.com
Is there any way outbounds calls can be equally distributed to allocated SIP?
Each trunk has free calls. We want to maximize the utilization of free calls usage by distributing the calls.
Please note the screenshot for better clarity.
Regards,
Deepak
Your outbound rule has main route 1 the trunk 5001, the rest of routes will be used only as backup, check here
You can limit the calls on each sip trunk, and if the trunk is busy then the system can try the next route.
If you want to distribute calls equally to each sip trunk, in that scenario you can also use prefixes and create three different outbound rules, so users can select which sip trunk to use.
There's no other alternatives for this.
SG_F7
