DND led indicator on Yealink
KleiDav
Hello
We have an hosted 3CX server, with local Yealink T46S phones.
Configured the phones with STUN, we had some problems so we've installed an SBC on our LAN.
Is it possible to show better LED indicators on the Yealink phones? Especially when extensions are DND
I mean, on the softphone, the indicators are green = available, yellow = on a call, red = unavailabe or DND
On the Yealink I have only Green or Red, no orange/yellow.
And when extension is DND or not available the LED stays green. It only goes red when on a call.
You could try using BLF on the extensions so they show green/red when in use and not in use.
Thanks but we already have BLF on the phones, and yes it shows when in use or not
but i'd like to show also when DND or unavailable, like on the softphone
now when in status DND, the BLF key stays green
Hello @KleiDav
Please note that status changes in 3CX are monitored by presence. That means that you will need to use a 3CX client to monitor the status of extensions. BLF keys on ip phones do not display status changes.
OK thanks :-(
This is another topic that should be made sticky.. i can not count the number of times I see this request for something that the phones do not support.
zipman
