DNS Record not valid
MIkePTW
Hi there, we have a customer who has been running 3cx for 4 years. Recently the DNS record provided to us no longer works sitename.3cx.co.uk . We are not able to ping that record etc . How do we get in contact for someone to look at why the DNS record has been removed?
It sounds like you are running an outdated version of 3CX (probably older than v 16.0.8.16). Upgrade to the latest v18 and you will be all set.
thaks for the quick reply.It was running an outdated version of 16 which I have just managed to upgrade as the upgrades would not go through! shall I just leave it a couple of hours? managed to get it to 18 about 30 minutes ago
unfortunatly this is still not working, the FQDN is still down if anyone has any ideas?
Please contact your partner to check if everything is ok
thanks Bitn2, we are the 3cx Partner and this is the first time we have experienced this issue with a customers FQDN! The system has been upgraded to V18 and is running well but it appears that 3cx's DNS is not resolving any more.
What happens if you run nslookup fqdn externally
nslookup carninglitrust.3cx.co.uk
Server: dns-resolver.business-access.co.uk
Address: 88.215.61.255
it cant seem to locate the record at the provider
A customer of ours had the same problem yesterday and ended up having to re-install the 3CX from a backup.
As the domain of the old FQDN was "my3cx.be" (which is no longer available), he also had to change FQDN.
Cannot ping the fqdn,
I suggest raising a support call with 3CX, so this issue can be investigated by them,
mazet
