Solved "Do not disturb" not working.
atlantisegidek
Forum User
My English is weak, sorry about that. I hope I can explain.
I have Yealink T19P E2.
I'm in the "Calls Queues". I'm getting "Don't Disturb" the phone. But my phone is ringing.
So I get to "Don't Dıstrurb" but my phone rings.
Thank you.
If you want a quick solution (and I hope I have understood your requirement) why cant your users simply log out of the queue they are in, this way they wont receive any calls regardless.
https://www.3cx.com/docs/pbx-queue-status/
Reactions: atlantisegidek
Move to the extension you want to check, pick "Forwarding Rules" then pick "Do not disturb (DND)" and check if "Log out from queues" is ON.
14226
Hi @atlantisegidek
Make sure to reset the phone and reprovision it automatically via 3CX to ensure that it follows our provisioning.
If you are using modified templates this feature may not behave as you expect it.
Guriqbal Singh
